Burning rubber smell and rubber or carbon particulate on aft of vehicle
3.6K views 11 replies 5 participants last post by  sc00b
#1 ·
Greetings, a new to me GS coupe seems to work well enough but on short intital drives smells like burning rubber. Noticed conspicuous deposits of what might be rubber or burned rubber carbon particles on aft of trunk and lower spoiler. Tires seem ok, shifts, etc. System voltage is strangely low at 11v but appears to have funcitoning alternator as a/c blows hard, lights are bright, continues to start and voltage does not get below 10.5 and climbs to perhaps 11.3 intermittently. No trouble lights. Exhaust is clear -- this stuff does not seem to be coming from the exhaust but seems to be carried under the car. Serpentine belt is intact.
#3 ·
Well, the car was delivered from an open-carry car carrier, and I am coming to think that the carbon particulate matter on the back half of the car is the remnants of diesel exhaust. Shockingly large particles, but that's what it seems to be, not rubber.
Driving the vehicle, I am not getting the clutch response in "sport" mode that I did in the other GS with the drive-by-wire feature installed. Much partial engagement in first up to a higher rev, lots of slipping in 2nd, almost all slipping in reverse but I have been told there is no full engagement of the clutch in reverse.
I am not seeing any obvious oil leaks, looking at the top of the engine. I don't recall burning oil -- which I have had coming from cars back to the then-newish Plymouth Roadrunner in 1970 -- smelling like rubber --- the smell here is of rubber. It will be getting on to a lift soon.
#8 ·
The particulate must have been diesel exhaust from the transport. It all washed off and the car detailed out quite nicely.
As to the smell, I am guessing that getting the GS off of the car carrier (one of the big ones) was accomplished by use of lots of reverse gear and possibly some use of "automatic" for forward. The clutch was likely the source. The evening of delivery I smelled it at the fuel stop 10 minutes later, but not the next morning. Oddly, when the car was in prepurchase inspection, the reading was 8% used (92% remaining), and at the local mechanic, those reading were reconfirmed. Both had the correct scan tools. But, the clutch is nearly worn out, by driving impression and perhaps by visual inspection. It is correctly adjusted. Mechanic says I may get a year out of it depending on how I drive.
Speculation is that someone "reset" the clutch wear indicator, which would seem akin to rolling back an odometer.
Fortunately the rest of the car just needed fluids changed which was done, along with new tires, and it's driving well now. Needs a stereo, and a reglue for the aft part of the headliner. Came with a very nice Bob Marley CD in the player.
#10 ·
I can't read the kiss point, but the two shops which have inspected the clutch can and did, as they have the factory and Leonardo tools respectively. I have to take their word that it is adjusted properly. The car does drive ok. I am having a DBW installed and that may make the clutch a little sprightlier and more often fully engaged.
#12 ·
catman is on the money. the wear indicator is only a ballpark and only when it was set up correctly when replaced. if the bedding and kisspoint/clutch configuration aren't completed and set correctly, the wear % will be askew for the life of it.
did they give you a wear index besides the %? should be a number in the thousands, 4000 is good and new, 10,000 is slipping and done for just about.
i've replaced many clutches, and the typical wear i've seen register on configuration is about 15% after adjusting kisspoint/PIS. the most i've seen worn is 147%. it isn't a 0-100% like a service reminder or oil life display. it is dynamic and changes as it adapts and drives.
